Forums >> Revit Building >> Technical Support >> Grid Bubble formatting between projects
Fri, Oct 24, 2014 at 1:40:23 PM | Grid Bubble formatting between projects
wgadams43
Hello,
REVIT 2014
I have 2 projects linked together. I only want to use 1 column grid. When I format the grid (move grid bubbles off one another, choose which grid line end to see the bubble, etc) I can propagate extents in the project that the grid is in but when I link it to the other project the formatting is lost and reverts to the original formatting. I've made a model group of the grid and opened that file and moved the grid bubble around and then saved thinking that would be what revit refers to when linking the grid but the formatting for the linked grid gets lost and the original formatting from when I set the grid up is what it reverts to. I can't figure out a way to modify the grid bubble locations once the project is linked.   I don't want to have to keep up with two grids if I don't have to. Can another help?
Thanks!
Sun, Oct 26, 2014 at 8:33:04 AM | Grid Bubble formatting between projects
In order to control objects like grids, you need to own them in your project.  the correct process for this is to use copy monitor.  You can read about that process in your help.
Different Grid Bubble for different scale views?
Thu, Dec 12, 2013 at 5:42:13 AM
Column grid text too wide to fit in bubble
Thu, Jul 1, 2010 at 8:32:06 AM
Grid Bubble Trouble Revit 2015
Fri, Sep 25, 2015 at 7:25:43 AM
Multi Segment Grid Line Bubble Issue
Wed, Dec 11, 2013 at 2:52:11 PM
Grid bubble in elevation
Sat, Oct 4, 2014 at 3:20:57 PM
Page generation time: 0.6371
