17 Users Online (15 Members):
Forums >> General Discussion >> Revit Project Management >> Wall assembly demolish schedule
I would like to know if I can make a quantities schedule with a finish of the wall, proposed for demolition. Exemple: I would like to make a schedule with the following columns:
FINISH   MATERIAL) / VOLUM / DEPARTAMENT / ROOM
Did you create walls that you actually demolished? If so, then you can schedule those using a material schedule with phase set accordingly - but not by room.
Wall 1 and 2 are existing walls. I want to demolate just the finishes (finish B), and i want to know the quantity of that.
You can't demolish finishes. You could create two walls. One without the finish and the other with just the finish and you would demolish that wall.
Perhaps a better wall to do this is to assign a new parameter to walls that you could use as a filter in your material takeoff schedule. Or you just assign a different material called demolished to the appropriate sides of those walls.
Wall Schedule showing Wall Assembly |
Thu, Apr 29, 2010 at 1:26:27 PM
Construction Assembly Schedule |
Thu, Aug 4, 2005 at 7:33:53 PM
Assembly Schedule:Part List |
Sat, Oct 29, 2011 at 2:32:38 AM
Existing wall assembly visable in New Construction phase |
Wed, Nov 2, 2011 at 5:49:09 PM
Wall quantities with offsets |
Tue, Feb 19, 2008 at 4:55:45 PM
11
