18 Users Online (16 Members):
Forums >> General Discussion >> Revit Project Management >> Revit Arch 2015 - Wall - Hide a Wall Layer line
0 Posts No Rating |
Hello guys. I have a problem that gives me crazy. I`m working on a project with some basic walls with multiple layers - 1. Structural Core Layer - Bricks , 2. Thermal layer - Insulation and 3. Finish layer - Plasterboard. I have a floor plan to scale 1:200 and I want to hide the contact cut line between the insulation layer and the finish layer inside the structure of the wall. Normally I can acheive that result by using the Linework Tool and setting the line style to INVISIBLE. But it`s a time consuming task with hundreds of walls. Is there any way doing that automatically by using the Graphics override panel for the specific view and makes that particular line invisible? =]
At 1:200 you should just set your view to coarse and that will get rid of your interior wall lines.
0 Posts No Rating |
Yeah, in the wall properties, maybe in "edit type" there is "coarse fill pattern". Choose an acceptable pattern and set your floor plans to coarse detail level. Then the layers will not appear.
door sash/head to project from a particular layer of a wall |
Fri, Apr 24, 2015 at 1:46:50 PM
Hiding linked Walls by Wall Type??? |
Wed, Oct 12, 2011 at 2:48:13 PM
How to control a single-layer wall? |
Wed, Apr 28, 2010 at 2:39:50 AM
EXPOR LAYERS for WALL HATCHES are missing |
Wed, Mar 1, 2006 at 8:30:58 AM
Exporting and layer modifiers |
Wed, Nov 16, 2011 at 4:04:33 PM
