Forums >> Revit Building >> Technical Support >> 3D Views with subtle shading
Thu, Oct 23, 2014 at 3:55:02 PM | 3D Views with subtle shading
Warchitect
4 Stars: 5 Votes
So some 3D views have this nice subtle shading.
I can make my other 3d views match it by making a view template of the one I want and apply it to the ones that need it. but I would like to know where that setting is. I simply can't find it.
here is a visual example
Thu, Oct 23, 2014 at 3:58:22 PM | 3D Views with subtle shading
That "shading" is automatic.  Material color changes automatically with the angle from your view ....and light if you have it on.
Thu, Oct 23, 2014 at 4:39:33 PM | 3D Views with subtle shading
Warchitect
4 Stars: 5 Votes
Sorry. its not the color shading on the surface. its that subtle darkening around the edges etc. if I make a 3d view its normal shading, but I have some that have that extra tonal effect across the surface, almost like an airbrushing tint at the edges...
Edit: found it. under the shading options, its the "ambient shading" check box is on.
Edited on: Thu, Oct 23, 2014 at 4:42:00 PM
Shading w/ Edges Color Differences
Thu, Jul 23, 2009 at 2:18:43 PM
Lines in 3D views...picture attached
Wed, Jul 30, 2008 at 11:26:38 AM
Shading Toolbar
Tue, Jun 22, 2004 at 9:54:36 PM
Walls in views that are set to “Shaded with edges” even though shadows are turne
Mon, Aug 11, 2008 at 9:00:45 AM
Toposurface from Autocad File
Mon, Oct 6, 2008 at 4:06:02 PM
Page generation time: 0.6819
