Forums >> Revit Building >> Technical Support >> Beginning problem for a beginner
Tue, Oct 21, 2014 at 2:17:38 AM | Beginning problem for a beginner
Skridtprgl
Hello, i'm fairly new to the mass modeling and family aspects of Revit.
I'm working on a church from the start of the century. I am familiar with the workings of revit, of how walls and curtain walls etc work. But this complex assortment of walls leaves me at a loss. If i do mass modelling, how can i make windows? since the curtain wall is just placed on either the inside or outside of the mass, and not the whole wall.
So... How would you advice me to model this building?
Thank you for your help!
I'm working in Revit 2015
Edited on: Tue, Oct 21, 2014 at 2:19:36 AM
Tue, Oct 21, 2014 at 2:18:55 AM | Beginning problem for a beginner
Skridtprgl
Tue, Oct 21, 2014 at 7:20:28 AM | Beginning problem for a beginner
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
I would use component in-place wall extrusion.
For your windows and some doors, you will need to modify your families to achieve these kind of wall opening shapes – use voids instead of wall opening element.
Tue, Oct 21, 2014 at 7:57:15 AM | Beginning problem for a beginner
DON'T USE MASS!!!  This is a good tool for sloping walls, really odd forms and quick planning but it is always preferrable to use regular revit components whenever you can.
See attached:
  1. Full thickness wall
  2. Create a face based, parametric void family to cut your wall step backs
  3. You will have to paint the step back faces
  4. Create an appropriate window family that has an adjustable exterior/jamb trim
Basic problem
Tue, Feb 26, 2013 at 7:29:28 AM
Beginning and End Stair Treads
Tue, Mar 31, 2009 at 3:16:55 PM
Keynoting Beginner, revit Architecture 2011
Fri, Mar 22, 2013 at 3:45:06 PM
Absolute Beginner
Fri, Mar 9, 2007 at 10:07:16 AM
12
Workflow for updating a master Revit model with project as-builts
Thu, Dec 30, 2010 at 9:04:07 AM
Page generation time: 4.3310
