Forums >> Community >> Newbies >> DOT NOT SEE LEADERS
Thu, Oct 16, 2014 at 1:49:21 PM | DOT NOT SEE LEADERS
PerferAutoCad
This just started happening.  While placing text (with a leader) i do not dymanically see the leader until after I type in the text and hit enter.  Whats up with that?
Thu, Oct 16, 2014 at 2:18:54 PM | DOT NOT SEE LEADERS
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I never see a leader before I do the text and add one it.  This is how Revit works.  I'm not sure how you saw one before
Thu, Oct 16, 2014 at 3:00:59 PM | DOT NOT SEE LEADERS
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
I always see the leader while I click the points. REVIT 2014 and 2015 tested. Something has changed. I'm not running 2015 R2.
Thu, Oct 16, 2014 at 4:38:55 PM | DOT NOT SEE LEADERS
fastjohnnyz
What release are you running? I am on 2015 update release 4 and the leader goes in and then I add the text and it works fine
Fri, Oct 17, 2014 at 10:23:58 AM | DOT NOT SEE LEADERS
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
I'd also test this out with an 'out of the box' project template file just in case it's file specific.
Howdy! I'm new!
Wed, Apr 14, 2010 at 1:29:56 PM
Can leaders and dimensions be modified
Mon, Dec 22, 2008 at 11:02:52 AM
Leaders moving_Annoying
Fri, Jan 20, 2012 at 7:37:30 AM
display edges and openings above the cutting plane in a dash dot dot linestyle
Thu, Mar 10, 2005 at 7:12:05 PM
Dimension with Tick and Dot
Fri, May 21, 2010 at 10:36:20 AM
Page generation time: 0.0369
