Forums >> Revit Structure >> Technical Support >> Seismic bracing models for subs??
Thu, Oct 16, 2014 at 8:57:09 AM | Seismic bracing models for subs??
lukedjr85
Hi everyone,  recently a manufacturer of seismic bracing stated that subcontractors are requesting BIM objects of his product.  We went back and forth with a couple questions and speculations and we have no idea what a sub would do with a BIM object that represents a seismic bracing component.
Have any of you run into this in the past?
Any speculations as to what they would use that for?
Thu, Oct 16, 2014 at 9:08:55 AM | Seismic bracing models for subs??
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I would assume they want to use it in section/detail drawings.
Bracing Shedules
Thu, Aug 27, 2009 at 2:53:25 AM
Wall Bracing (plywood sheets)
Sun, Aug 19, 2007 at 7:04:04 PM
Vertical bracing symbolic line ???
Tue, Jun 4, 2013 at 7:33:50 AM
Revit 2014 Vertical Bracing Problems
Thu, Feb 20, 2014 at 10:26:00 AM
PLACING GIRTS AND BRACING
Fri, Oct 24, 2008 at 8:44:01 AM
Page generation time: 0.0780
