Forums >> Revit Building >> Technical Support >> Unable to create floors or stairs in my model
Wed, Oct 15, 2014 at 3:35:12 PM | Unable to create floors or stairs in my model
DannyClark89
Hi there, I am relatively new to revit and I am currently having some problems in Revit 2015 and more specifically this project I am working in. I had placed my first set of stairs within the project on the ground floor i.e. Level 0 but frustratingly, when I put a second set of stairs on level 0 I am prompted with a warning message saying "Cannot use work plane". Please see attached image for further details. I must note that I have no problem placing a second set of stairs on Level 1 i.e. First Floor. This is what I done and then offset the base offest to coincide with Level 0 datum level. This looks fine but i would rather know the problem causing this. My second issue occured when I tried to place a floor on Level 0 which I was prompted again the same warning message. What is making me unable to place anything on this plane?
My last issue is that when I select the snapshot on Level 0 the camera locks to the middle of the screen and completely dissociates from my cursor which has no control. Please seem image attached I must add the snapshot works fine on Level 1.
There is clearly a link between all these issues associated with Level 0 I can understand that, but the cause I am completely unaware of. Any help on this matter is greatly appreciated.
Wed, Oct 15, 2014 at 4:11:22 PM | Unable to create floors or stairs in my model
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Did you try doing as the error says and change your workplane in that view to your Level 0?
Wed, Oct 15, 2014 at 5:30:15 PM | Unable to create floors or stairs in my model
DannyClark89
Unfortunately I have no idea how to edit the work plane to suit Level 0. Can you provide me with some advice please?
Wed, Oct 15, 2014 at 5:59:26 PM | Unable to create floors or stairs in my model
DannyClark89
OK thanks for the heads up, I have figured it out! it was relatively easy to be honest! Cheers!
STAIRS...Multi Story
Fri, Jan 18, 2008 at 7:47:11 AM
Multi level stairs with different heights
Tue, Dec 10, 2013 at 7:10:57 AM
2 sets of stairs, 1 landing, 1 cutback. possible?
Sun, Mar 1, 2009 at 3:28:10 AM
Attaching stairs to floors
Wed, May 24, 2006 at 11:29:47 PM
Unable to rotate/align surface pattern on stairs
Thu, Aug 28, 2014 at 7:29:20 AM
Page generation time: 1.7341
