16 Users Online (14 Members):
Forums >> Revit Building >> Technical Support >> Ceiling serious error
0 Posts No Rating |
Hi there! I'm having a huge problem when trying to make a ceiling either with the automatic and the sketch tools. When I click on the tool button, a message appears informing there has been a serious error and asking if I want to save a recovery file, but however, the programme does not close, and if I select another tool, it works normally.
I re-installed and repaired the software, updated it, audited the file, unchercked hardware acceleration.... It only happens with this file, which is quite a big one (2000-2500 elements) but I'm desperate, because this file means my final project to become an architect. Hope someone can help me.
By the way, I'm using Revit 2014 (64bits).
Do you have all of the updates installed?
0 Posts No Rating |
Yes, I installed them and nothing changed
Do a saveas, create a new project and then load in a different but similar ceiling family and over write the old family.
0 Posts No Rating |
After uninstalling, installing, updating, downloading hotfixes and many others, I've managed to solve it in a very simple way; I've transferred all the project standards to a new file and then copy-paste every single entity in the new file and it worked. There might be a bug or something in my old file.
Thank's anyway
Revit Ceiling Causing "Serious Error Has Occurred" Message |
Thu, Aug 29, 2013 at 3:01:57 PM
Automatic Ceiling error - less than 150mm |
Mon, Mar 3, 2014 at 7:40:48 AM
Sloping Ceiling |
Mon, May 25, 2009 at 2:35:31 AM
Walls will not connect to ceiling or roof |
Mon, Mar 2, 2015 at 8:25:47 AM
Ceiling Fixture Orientation |
Tue, Sep 13, 2011 at 9:02:13 AM
