Forums >> Revit Structure >> Technical Support >> dimension change when importing AutoCad file
Wed, Oct 15, 2014 at 6:24:02 AM | dimension change when importing AutoCad file
willkerr
Hi all,
I have been trying to import an AutoCad file into Revit and so far have been relatively unsuccessful. I have been using the Import CAD function and manage to get the image into revit, however the dimensions on the drawing in Revit are much smaller than those in AutoCad.
It is not a complex file, just lines, but the shapes are difficult to replicate accurately.
I am using Revit 2014 and the CAD file was created using AutoCAD Civil 3D 2012.
Am I failing to properly prepare the file for import into Revit or is there something else I am missing?
Thu, Oct 16, 2014 at 10:59:01 AM | dimension change when importing AutoCad file
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Sounds like you have a 'units' problem. Make sure the units of the imported CAD file coorispond to the units in the REVIT file. Worst case scenerio scAle the CAD file in REVIT. Always pay attention to the units settings as you import the CAD file.
IMPORTING AUTOCAD pgp FILE
Tue, Apr 12, 2016 at 9:21:30 AM
Dimension issues when exporting to AutoCAD
Mon, Nov 19, 2007 at 4:51:13 PM
Error when importing an AutoCAD File
Wed, Oct 31, 2007 at 5:49:58 PM
Wiggly Lines when importing Topo into Revit
Tue, Jun 28, 2016 at 9:46:19 AM
importing from AutoCAD
Thu, Jul 19, 2007 at 1:47:15 PM
Page generation time: 6.4133
