Forums >> Revit Structure >> Technical Support >> 3d Cornice & Skirting Advice
Tue, Oct 14, 2014 at 9:42:35 PM | 3d Cornice & Skirting Advice
raja15
Hi there.
I'm currently using Revit 2014 on Windows 7.
This is not so much a question as it is just wondering how other users are using their 3D.
We are looking at fine tuning our documents and utilising 3D more, where we can, to reduce time in drawing elements in 2D all the time.  Just wondering what the best way is to create 3D cornice & skirting.
At the moment we have been drawing detail lines in our sections and internal elevations to indicate both the cornice & skirting. The idea of using the 3D would be so that when we go to create these views (especially with our bigger projects) that all this information is already shown in the view and we don't need to manually draw it in.
I've already researched creating components and hosting them to the wall face, ceiling, etc but just wondering if there are any better ways out there which I haven't thought of or come across.
Any advice, ideas, etc would be appreciated.
Thanks in advance.
Tue, Oct 14, 2014 at 10:56:31 PM | 3d Cornice & Skirting Advice
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
I’m not sure what ‘skirting’ you’re referring to, but wall cornice you can create with a wall sweep. Use profile family to create a cornice shape (cross section) and apply to wall with Wall: Sweep tool, or apply to a wall type as an integral part of the wall.
Sun, Nov 9, 2014 at 8:21:30 PM | 3d Cornice & Skirting Advice
raja15
By skirting I mean the skirting boards which sit at the bottom of the wall to hide the join between the floor covering and wall sheeting.
And thanks for those ideas I'm about to research into them more so we can apply them to our documents.
Mon, Nov 10, 2014 at 11:09:13 AM | 3d Cornice & Skirting Advice
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
we usually call skirting boards "base boards"
Mon, Nov 10, 2014 at 11:41:34 PM | 3d Cornice & Skirting Advice
raja15
In Australia we call them skirting boards
Advice - Wall Cornice
Fri, Feb 3, 2012 at 12:05:51 PM
Applying skirting boards to walls
Fri, May 20, 2011 at 7:18:42 AM
Skirting boards
Tue, Dec 15, 2015 at 3:36:54 AM
skirting
Sun, Jan 7, 2007 at 8:47:58 AM
Cornice on exterior wall disappears when I place window 2' above it?!
Mon, Nov 28, 2011 at 2:22:07 PM
Page generation time: 0.2769
