23 Users Online (21 Members):
Forums >> Revit Building >> Technical Support >> Printing in Revit
11 Posts No Rating |
I am currently preparing area analysis plans with different colors. I have the plans in sheets. When I send the sheet to plot the output contains a plan with area colors and the legend prints with no color. It only prints the area name a square where the color would be and no color. Has this happened to anyone before? We have tried to print to all out color HP 1050 plotters and nothing. We believe it is a memory issue or a problem with Revits print program. Please advise...
Thanks
Daniel
if you browse through the printer options before printing you will come along a space where you can choose to use dark only, or color, grayscale, etc. the problem may be that color is not selected. this should do the trick
Our printing settings are already set to color. We think it could be a problem with the HP drivers. The colors print when we make PDF files.
Printing Query |
Wed, May 23, 2012 at 7:54:08 AM
Printing Problems Revit 2012 |
Wed, May 16, 2012 at 7:31:01 AM
printing press |
Wed, Dec 29, 2010 at 11:28:44 AM
Printing Lighting Plans in Revit MEP |
Mon, Mar 14, 2011 at 9:20:35 AM
Fill Region set to Transparent but printing Opaque [ 1 2 ] |
Sat, Jan 26, 2019 at 12:16:15 AM
18
