Forums >> Revit Building >> Technical Support >> revit 2014 - One particular view crashes revit
Mon, Oct 13, 2014 at 3:52:13 PM | revit 2014 - One particular view crashes revit
motodesign
I have a roof view, pretty simple view, but when I double click it the Project Browser, the view starts to switch, but then I get the spinning wheel and revit hangs and I have to force quit.
This is a working view, so I can delete it except for one thing.  I have floor plan callouts on this view.  If I delete the view, how do I get those floor plan callouts to show up on another roof plan?
Thanks for your help-
Mon, Oct 13, 2014 at 4:40:38 PM | revit 2014 - One particular view crashes revit
motodesign
Soo, I can't delete that view.  It deletes the other views.  grrrr.  anyone have any ideas why this one view crashes Revit?
Fri, Oct 17, 2014 at 8:13:18 AM | revit 2014 - One particular view crashes revit
Did you audit your file?
Tue, Oct 21, 2014 at 12:00:44 PM | revit 2014 - One particular view crashes revit
motodesign
Yes, I audited it a few times.
Tue, Oct 21, 2014 at 12:41:10 PM | revit 2014 - One particular view crashes revit
Be careful if you are using dependent views....
It sound like you will have to create a new plan and callouts.  You can open the new callouts and copy paste/ same place from the old callouts to the new one.  Then delete your plan and all the callouts.
Tue, Oct 21, 2014 at 3:17:56 PM | revit 2014 - One particular view crashes revit
archigrafix
5 Stars: 4 Votes
Do you get any sort of Revit error window? We have experienced a few crashes related with the graphic card, so I would suggest updating the graphic card drives and make sure you are using the latest Revit 2014 update.
Marc Faber
BIM Solutions Developer
goto.archi | Oslo, Norway
Wed, Oct 22, 2014 at 1:39:30 PM | revit 2014 - One particular view crashes revit
motodesign
Nope, no error.  It just locks up with a blank view, some menu items are still there in the ribbon.
Thu, Oct 23, 2014 at 6:44:06 PM | revit 2014 - One particular view crashes revit
ladrillero
5 Stars: 3 Votes
Try to open the project in another PC to see if you get the same problem. That may give you a clue.
Revit 2014 Update 2 crashes constantly on Nvidia Quadro FX 3800 cards [ 1 2 ]
Sun, Sep 20, 2015 at 11:28:23 PM
17
Revit crash when dimensioning
Wed, Feb 12, 2014 at 9:28:22 AM
Revit crashes when placing keynote legend
Tue, Jul 25, 2017 at 2:07:43 PM
Revit 2014 Issue- Dragging Views Into Sheets & System Crashes
Wed, Apr 27, 2016 at 5:47:08 PM
Exporting RPC content from Revit 2014 to Max 2014
Tue, Aug 19, 2014 at 10:26:21 AM
Page generation time: 3.2875
