Forums >> Revit Building >> Technical Support >> Custom Window Cut
Mon, Oct 13, 2014 at 12:41:33 PM | Custom Window Cut
mystykal06
Hi everyone,
I spent several hours on how i could get a custom window cut on a window family. There is some information regarding custom window cuts, but i couldn't find anything close to what i am trying to achieve. I attached a picture so you guys can point me to the right direction on what technique i should use. You dont need to make it for me, just share how you would tackle this problem.
Thank you for your time.
Mon, Oct 13, 2014 at 1:36:59 PM | Custom Window Cut
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Are you tring to do this in section only? If so you can use the Cut Profile tool.  You could also do this using a wall reveal or in-place void to cut your wall
Mon, Oct 13, 2014 at 2:32:56 PM | Custom Window Cut
mystykal06
Thanks teafoe5, i ended up solving this problem, i used your sugestion: in place void.
Thank you for the quick reply.
window does not get cut in plan view.
Tue, Jul 12, 2011 at 10:37:20 AM
Window family doesn't cut properly in plan
Wed, Aug 14, 2013 at 6:55:42 AM
Custom Window Frame
Tue, Aug 2, 2011 at 12:31:51 PM
Custom Window Opeing in revit 2010
Thu, Aug 5, 2010 at 10:44:04 AM
Custom window family glazing problem
Fri, Mar 27, 2009 at 2:26:30 PM
Page generation time: 2.0449
