29 Users Online (27 Members):
Forums >> General Discussion >> Revit Project Management >> Tagging Wainscott and Wall above
On my main level floor plan, I would like to tag both the 3' tall wainscott and the rest of the wall that goes up to the roof. Currently only the top wall tags and I cannot tab through to select the wainscott below. My view range goes down to 0' off of main level so I know the wainscott is technically visible. I have a dummy tag that I use to show stacked wall tags but I would prefer to tag the walls with true annotation tags that update if the type mark were to change.
Thanks for any help
Change your cutplane temporarily so that it cuts this wall then tag it. I can't remember if the tag will stay when you move the plane back up.
Excellent idea, I have been moving around the building and hiding the walls above temporarily and tagging the wainscott. Thank you
Tagging a Copy/Monitored Wall |
Wed, Jun 22, 2016 at 4:06:50 PM
Problems tagging wainscottting wall sweeps |
Wed, Jun 20, 2012 at 2:34:37 PM
Tagging items based on view |
Wed, May 9, 2012 at 3:01:54 PM
Tagging Graphical Column Schedule |
Wed, Nov 24, 2010 at 8:41:14 PM
tagging a curtain wall |
Tue, Nov 9, 2010 at 2:10:00 PM
