Forums >> Revit Building >> Technical Support >> Extending stair railings
Thu, Mar 9, 2006 at 5:16:17 PM | Extending stair railings
JAIMERIOSJR
I am working a project using stantdard stairs/railings in revit. The result is that the rail stops at the end on the post and does not extend beyond. either top or lower risers. what do I have to do to extend them? Thanks.
Mon, Mar 13, 2006 at 2:49:21 AM | RE: Extending stair railings
eldados
eldados Avatar
4.5 Stars: 8 Votes
you will need to go to the rail properties--> edit new--> baluster placement click edit, at the bottom half you'll have all sorts of wonderful stuff to play with Smile try to change setting under space for end and start post...
Integrator
KarelCAD
Thu, Mar 16, 2006 at 4:36:40 PM | RE: Extending stair railings
JAIMERIOSJR
I tried all different options and I could not get the top railing to extend beyond the bottom rise without placing railings and post at the end. Any specifics in how to extend the top rail bwyind the bottom riser?
Sun, Mar 19, 2006 at 9:20:29 PM | RE: Extending stair railings
eldados
eldados Avatar
4.5 Stars: 8 Votes
sorry mate, didn't have time to try, i don't think you will be able to do this... will investigate further...
Integrator
KarelCAD
Railings for spiral stair is not following stair incline
Mon, May 20, 2019 at 8:36:25 PM
stair railings-inserting glass
Mon, Dec 9, 2013 at 11:37:40 AM
Problems attaching railings to stairs
Mon, Dec 2, 2013 at 10:49:14 AM
Railings
Tue, Dec 4, 2012 at 10:31:40 AM
Dimensioning railings
Fri, Jul 24, 2009 at 3:04:00 PM
Page generation time: 1.2212
