20 Users Online (18 Members):
Forums >> Revit Building >> Technical Support >> Wall won't show in North elevation
2 Posts No Rating |
It shows fine in 3d view but won't show in North elevation? This has happened before but I never found the fix.
I use 2013
Also, why can't I get all the datum levels to show in East elevation? The lowest one won't show up
Thank you!
Gary
Is your elevation cut plan in front of the wall? If its behind the wall the wall want show up. Also your level needs to cut through the view to be seen. You can go to a view where it does show up select it and right click and select maximize 3d extents to have it show up in all your views.
2 Posts No Rating |
Sorry, but I don't understand how the cut could be behind the wall? The camera is well away from the model and it is set to no clip, just like the other elevation views?
I tried the right clicking on a good elevation/level, right clicking and max 3d with no help.
What do you mean camera? There is no camera with an elevation.
If you mean the elevation symbol, click on it and it will show where the cut line is. The cut line does not have to be at the symbol.
Also, Did someone hide it, is it in a different workset that is not on, is it phased?
2 Posts No Rating |
I moved the camer WAT awat and a ine showd cutting the model. I drg it away and that tok care of it.
Thanks
2 Posts No Rating |
Way away drug
Structural beam won't show in elevation |
Fri, Aug 12, 2005 at 5:22:08 PM
Elevation won't show in preview and can't be printed out |
Fri, Nov 20, 2015 at 10:58:59 AM
Doors on North wall showing up on South elevation |
Sat, Feb 4, 2017 at 5:21:33 PM
Can"t see wall and other items in north elevation |
Wed, Feb 24, 2016 at 2:18:22 PM
Wall Section won't show in both plan and building section |
Wed, Jan 29, 2014 at 6:52:25 AM
