16 Users Online (14 Members):
Forums >> Revit Building >> Technical Support >> Folding door as curtain panel
Hi, I can't find anywhere a stacking/folding door as curtain panel, preferably parametric. It's a huge shame that after spent thousands of dollars, and after all those years, Revit still do not come with (really usable) parametric families into the libraries.
Thank you for any directions.
Why would you want a folding door as a curtain panel?
http://seek.autodesk.com/search/folding%20door?source=SearchBox&locale=en-us&globaldd=globaldropdown.option.b
This is an architectural question, not a bim technical one. The entire façade is a curtain wall. The door as a curtain panel is a several years old Revit functionality.
You do not have to use a curtain panel door, you can use a wall hosted door like the ones shown on Autodesk seek..
- Make sure the CW framing is spaced correctly for your door
- Swap out the panel for a generic wall
- Place your wall hosted door in your wall and adjust its location.
- If you have to, readjust your grids
The attached automatic slider is "in" a curtain wall.
Thank you, this is a great way to make it. I was aware of the conventional wall panel clue, but was blindly in search for a panel.
I know this is a rusted issue.
but take a look anyway...
Here is a solution for any folding doors you want.
https://youtu.be/dTlFO6dRm8c
Edited on: Wed, Jun 17, 2020 at 9:07:46 AM
want more?
You can get more tips at Enjoy Revit |
Curtain Wall Panel to Curtain Wall Door |
curtain panel door not reading completely in schedule |
Thu, Jun 30, 2011 at 1:56:58 PM
Curtain system panel problem |
Tue, Jul 10, 2007 at 10:08:07 AM
Curtain wall sliding door |
Fri, Jul 25, 2008 at 10:31:57 AM
Panel tags for glass doors with frame in curtain walls |
Thu, May 1, 2014 at 7:51:48 AM
