13 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> schedule showing wall height
I am trying to make a material schedule sorting (concrete) walls by wall height. (concrete bidders price x linear feet of each certain wall height) Unconnected wall height" is a constraint that is displayed in the properties. Not available as a parameter to display in a schedule. I tried a calculated field (area/length) which gives inaccurate info especially on short walls due to the way walls are joined.
Is there a way?
Believe it or not I don't think there is a way ! Walls can also be attached from their bottom or top to other elements and can have edited profiles. I seem to recall playing with this (more than once) and not coming up with a way to schedule wall height outside of creating a project parameter (Manual Wall Height) and MANUALLY inputting each wall height which is perposterous. This would be very labour intensive and a huge undertaking but at the end of the day it would give you what you want but would not be parametric or automatic and would require baby sitting.
I didnt think so. I tried to kluge it in by making a formul that divided the area of the wall by the length (since those 2 parameters are available) but it gives fractional results that are way off on short walls due the joining and beveling.
2015 wall height |
Fri, Jul 10, 2015 at 9:17:02 AM
I can't see "Height" parameter value of Wall or Currtain Wall Schedule? |
Thu, Apr 27, 2017 at 2:04:39 AM
scheduling height of irregular curtain wall panels |
Sun, Mar 11, 2012 at 12:08:00 PM
Room schedule with ceiling height |
Fri, Jul 13, 2007 at 11:01:42 AM
Wall Schedule showing Wall Assembly |
Thu, Apr 29, 2010 at 1:26:27 PM
