Forums >> Revit Building >> Technical Support >> Dimensioning with keynotes
Thu, Oct 2, 2014 at 11:02:38 AM | Dimensioning with keynotes
trmurphy21
hi. i am working on a detailing sheet with keynote references to the lengths of rebar etc. is it possible to either create or change the dimension text to a keynote tag? or if anyone knows of a workaround
also looking for a line based (side) metric UB detail component family if anyone has one would be great!
thanks
Thu, Oct 2, 2014 at 11:06:08 AM | Dimensioning with keynotes
There are no variables in keynotes.  Change the keynote and it changes everywhere it is used.  So obviously it is not goor for dimensions.
You could have a tag that reads a length parameter .... must be shared parameter.
Edited on: Thu, Oct 2, 2014 at 11:32:13 AM
Thu, Oct 2, 2014 at 1:22:12 PM | Dimensioning with keynotes
trmurphy21
thanks for the reply i found a workaround to right click in the text over-ride and select US that gets rid of the dimension then just have a keynote with no leader seems to work so far
Keynotes
Thu, Mar 15, 2018 at 3:15:03 PM
Keynotes
Thu, Oct 6, 2005 at 5:13:33 PM
KEYNOTES: only one keynote txt file and legend?
Wed, Jan 17, 2018 at 12:33:01 PM
some keynotes not printing
Thu, Sep 15, 2016 at 4:43:39 PM
Keynotes - Ledgend management
Mon, May 11, 2009 at 7:01:29 AM
Page generation time: 0.6195
