Forums >> Revit Building >> Technical Support >> Ghost Lines
Wed, Oct 1, 2014 at 6:09:16 AM | Ghost Lines
TimGarry
Hi All,
Currently using Revit 2015 Ultimate and experiencing an issue with what I am referring to as ghost lines.. I first came across this on a plan view and although the lines which appear a very soft grey did not match the outlin eof the pad below the floor plan, having delected the pad, the lines did dissapear so it was short fix in some ways and now they have reappeared on my elevations, I have attached a couple fo snaps for your information. Now, they do not seem to match anythin gin the rooms themselves as they are too low for ceiling heights and I have not popoulated the internals of any rooms to much extent so really puzzled over what is going on heere and any advice/help would be much appreciated...
Many Thanks
Tim
Wed, Oct 1, 2014 at 7:28:56 AM | Ghost Lines
I doubt the PAD lines "reappeared" in your elevations.....Must be different lines - right?
Did you try clicking on the line?
Did you try turning off 1/2 of your model VG elements, and repeating 1/2 of what's left until you find out what category they are in.   You should narrow that down in just 4-5 tries or less.
Thu, Oct 2, 2014 at 3:46:53 AM | Ghost Lines
TimGarry
Sorry not sure hwta you mean by turnin goff 1/2 of the VG elements?
I ahve turned off al imported categories and it stil remains?
To describe it even more, when you scroll into the view, the lines dissapear, only when the view stops scrollling/zooming do they appear, very light grey and not clickable? Very strange as they dont seem to represent anything behind / in the model??
How to delete Ghost Windows in the Model?
Mon, Apr 28, 2014 at 2:56:19 PM
Windows below only show when Ghost Surfaces is turned on?
Thu, Feb 2, 2012 at 4:44:00 PM
ghost callouts
Wed, Oct 11, 2006 at 7:20:33 AM
Sheet Number Already in Use...I have ghost sheets.
Tue, Nov 21, 2017 at 8:47:10 PM
Revit 2012 to Revit 2016 - Removing Ghost Surfaces Visualization Effect
Thu, Mar 31, 2016 at 10:00:40 AM
Page generation time: 0.2437
