Forums >> Community >> Newbies >> Linked cad file missing text
Tue, Sep 30, 2014 at 8:33:14 PM | Linked cad file missing text
Jamie351
Jamie351 Avatar
4 Stars: 7 Votes
Hey guys I link in my survey plan from the land surveyors for adjoining dwellings and levels althought on my shadow plans some of the text off the cad file is missing.
Is there something I need to do to the cad file once I link it into revit? Cheers.
Revit 2018........
Wed, Oct 1, 2014 at 7:49:49 AM | Linked cad file missing text
Not nearly enough information.
Is the layer, that the text is on in the CAD file, on in VG settings in your view?
Is your view cropped?
Is this portion of the 2D file covered by a 3D object that is above it?
Thu, Oct 2, 2014 at 12:40:37 AM | Linked cad file missing text
Jamie351
Jamie351 Avatar
4 Stars: 7 Votes
yes all layers are on.
the view is cropped but not near where some of the text is missing.
nothing is covering the portion of the 2d file.
I will have a dimension off the 2d cad file. Will show the dimension and the arch ticks but the measurement will be gone.
Title boundary measure ment the word title will show part of the letter E the rest is blank. its just random not sure why...
Revit 2018........
Fri, Oct 24, 2014 at 4:57:19 AM | Linked cad file missing text
rendermaster
use Import CAD,then set the scale to the one used in the source drawing, then explode.
Fri, Oct 24, 2014 at 7:32:52 AM | Linked cad file missing text
Don't explode CAD unless you really want problems.  If you need to explode CAD, do it in an emtly project where you clean it up then copy paste from that into your project.
Wed, Dec 3, 2014 at 7:04:46 PM | Linked cad file missing text
Jamie351
Jamie351 Avatar
4 Stars: 7 Votes
is there a way to ensure the cad file is on top? like bring to front?
Revit 2018........
Wed, Dec 3, 2014 at 10:42:12 PM | Linked cad file missing text
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Select cad link and set 'draw layer' to 'foreground' in properties.
RAC 2009 - Text in CAD file is not plotting?
Wed, May 27, 2009 at 9:27:50 AM
Constraining to linked CAD file
Thu, Apr 4, 2013 at 3:09:14 AM
Linked in CAD text
Fri, Aug 16, 2019 at 8:25:10 AM
Problem exporting view with linked CAD file
Wed, Mar 18, 2009 at 3:46:34 PM
revit freezing and not responding when cad file linked
Fri, Feb 6, 2015 at 11:24:56 AM
Page generation time: 6.4766
