Forums >> General Discussion >> Revit Project Management >> problem printing line weight to pdf
Mon, Sep 29, 2014 at 1:00:56 PM | problem printing line weight to pdf
etrod1968
I am trying to plot a dwg to pdf and the line weights are not coming thru to the pdf. (if I send the same view to my printer it plots fine) I am using bluebeam does anybody know what could be causing this?
Mon, Sep 29, 2014 at 1:06:22 PM | problem printing line weight to pdf
You have to look at your printer settings.
Tue, Sep 30, 2014 at 3:31:49 PM | problem printing line weight to pdf
etrod1968
Found it there is a setting in bluebeam to turn off or on line weights.
Black lines printing grayscale in PDF
Fri, Oct 10, 2014 at 4:46:46 PM
Printing PDF Line Drawing - Wont show surface textures
Tue, Oct 23, 2012 at 9:24:39 AM
Printing with Shadows on and PDF
Wed, Jun 3, 2009 at 1:54:17 PM
Losing wall tags when printing.
Fri, Jan 20, 2017 at 9:07:39 AM
pdf printing
Tue, Sep 12, 2006 at 4:06:26 PM
Page generation time: 3.2966
