Forums >> Revit Building >> Technical Support >> Hatch Patterns messed up
Fri, Sep 26, 2014 at 10:50:27 AM | Hatch Patterns messed up
jmkennedy
Using Revit 2012.
In my current file a bunch of the hatch patterns (drafting) are messed up.  For example the lines in all my wood & gravel patterns don't match up anymore and they look like crap.  I opened up another Revit file and there are no issues with the hatches in that file.
This happen to anyone else?  Any suggestions on how to fix it?  I audited the file on my last open and it didn't make a difference.  I'll try to recreate a pattern or 2 from my .pat file but hopefully there is a simpler fix.
Fri, Sep 26, 2014 at 10:54:12 AM | Hatch Patterns messed up
jmkennedy
Update - I tried making a new hatch pattern to match from a fresh .pat file and it has the same issues.  Its like there is some origin problem or something with the hatches... but I can't think of any way to edit that in Revit.
Fri, Sep 26, 2014 at 7:28:32 PM | Hatch Patterns messed up
hugh
3.5 Stars: 4 Votes
Does your project have a distant origin? In AutoCAD hatching well away from the origin reliably scrambles some hatch patterns (due to pattern definition imprecision) until the hatch origin is adjusted.
I'm grasping at straws but have you tried adjusting the patterns' "Orientation to Host Layers" as WWHub mentioned here:
http://www.revitcity.com/forums.php?action=viewthread&thread_id=20131
Also, could you upload the fill .PAT file you just tried making a new pattern from? Respecification to higher precision can do wonders for hatch pattern appearance at high co-ordinates - but only if that is the reason for your problem.
Hugh Adamson
www.hatchkit.com.au
Custom Hatch Patterns
Thu, Dec 23, 2004 at 3:00:32 PM
Hiding Hatch Patterns [ 1 2 ]
Sat, Aug 29, 2009 at 8:12:25 AM
15
imported acad hatch patterns
Sun, Nov 25, 2007 at 6:39:02 PM
Stone Hatch Patterns - Looking for a good source.
Sat, May 4, 2013 at 4:59:24 AM
How to Import Hatch Patterns
Thu, May 31, 2012 at 1:16:12 PM
Page generation time: 1.0564
