Forums >> Revit Building >> Technical Support >> .dwg, .sat file import problems
Thu, Mar 9, 2006 at 8:35:28 AM | .dwg, .sat file import problems
nscshwn08
i imported a file as both a .dwg and a .sat file into my revit project. i cannot get the imported file to rotate in the 3d plane though. it will only rotate in the 2d plane. it is a model of a astronomical dome, and i need to rotate it to the correct position so i can place it in the building correctly. is there any way to get this done? thanks for any suggestions.. Shawn
Mon, Mar 13, 2006 at 2:59:50 AM | RE: .dwg, .sat file import problems
eldados
eldados Avatar
4.5 Stars: 8 Votes
have you tried to rotate in sections? don't think you'll be able to rotate in 3d...
Integrator
KarelCAD
Import SAT file
Fri, Nov 30, 2012 at 9:42:19 AM
Import SAT file w/ material & section cut
Fri, Jun 29, 2012 at 10:03:25 AM
2010 Conceptual Massing and .sat files
Fri, May 27, 2011 at 12:46:18 PM
Import DWG problem with size
Mon, Dec 6, 2010 at 7:33:32 PM
Revit and Sat file importing pc spec?
Mon, Mar 15, 2010 at 11:55:15 AM
Page generation time: 0.9148
