Forums >> Community >> Newbies >> Drawing 3D Families
Wed, Sep 24, 2014 at 5:04:54 PM | Drawing 3D Families
mrestim8or
Hi,
My name is Mike and I am looking to learn how to draw 3D families in Revit.  I am currently using Revit 2013.  Any advice on videos, books, blogs, etc, would be appreciated.
Thanks
Thu, Sep 25, 2014 at 2:09:52 AM | Drawing 3D Families
revitape
revitape Avatar
4.5 Stars: 9 Votes
Practice makes perfect... I am self taught and you can see how far I've come at the link in my signature. Start with simple modeling techniques and understand the use of reference planes. Then move on to creating simple parameters that allow your families to be flexible. Finally, put both those things together so you can create complex parametric families. That's about the simplest step by step process you'll hear but there's a lot to learn in between all those things.
Also, don't over build and keep your files as small as possible!
Good luck!
High quality modern Revit furniture!
www.therevitcollection.com
The Revit Collection: High Quality Revit Families | Revit Furniture
Thu, Sep 25, 2014 at 7:21:17 AM | Drawing 3D Families
http://revit.downloads.autodesk.com/download/RAC2009/Families_Guide/ENU/Family_Guide/PDF/ArchitectureFamiliesImpENU.pdf
Don't worry that it says 2009.  Almost 100% of this is still applicable.  Read and study this before you go any furthur.
Mon, Sep 29, 2014 at 12:25:43 PM | Drawing 3D Families
mrestim8or
Thanks for the advice
Mike
Worksets: Copying from one drawing to another?
Tue, Jan 5, 2010 at 4:53:39 PM
Resizing Families - Landscaping
Wed, Jun 20, 2007 at 5:21:12 PM
Help: Copying families from one drawing to another
Mon, Apr 21, 2008 at 3:27:22 PM
graphic problems with lighting fixtures
Wed, Jul 16, 2008 at 3:58:01 PM
ID Numbers and Unasscoiated Families In Revit MEP
Tue, Nov 29, 2011 at 12:12:18 PM
Page generation time: 0.5096
