Forums >> Revit Building >> Technical Support >> Adaptive component multi-profile sweep (R13)
Tue, Sep 23, 2014 at 6:50:04 PM | Adaptive component multi-profile sweep (R13)
revitape
revitape Avatar
4.5 Stars: 9 Votes
Alright, I feel like I'm missing a major step here so hopefully someone can help me out.  You can see I am trying to make an undulating multi-profiled chair backrest. It has been modeled in CAD as the pic shows.
(As I trial run I did a much simpler version than the exact object.)
First, I made a Reference Line using the spline option.
Second I adjusted the height and location of each of the nodes to be similar to the CAD backrest.
Third I chose the first, middle, and last nodes to be "made adaptive" using the tool of the same name.
Fourth, I placed the desired profiles (which is also an adaptive family loaded in) at those nodes and selected "Create Form".
Fifth, I failed miserably.
I know I am screwing something up because just using simple paths and profiles isn't working either. So what am I doing wrong?
High quality modern Revit furniture!
www.therevitcollection.com
The Revit Collection: High Quality Revit Families | Revit Furniture
Tue, Sep 23, 2014 at 10:07:12 PM | Adaptive component multi-profile sweep (R13)
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
I think what happened was you didn’t put your profiles on the correct AP’s ref plane. The profile has to be perpendicular to the path. Ref point has 3 x,y,z ref planes and one that is perpendicular to the path. It is easy to pick the wrong one, but if you select your ref/adaptive point and check ‘Show Normal Reference Plane Only’ in the properties, the only correct (perpendicular to the path) plane will be visible – much easier that way. Hope it helps.
If still no luck, can you upload you file?
Tue, Sep 23, 2014 at 10:52:42 PM | Adaptive component multi-profile sweep (R13)
revitape
revitape Avatar
4.5 Stars: 9 Votes
I did what you said and still got the same result. Thinking maybe it was my file, I tried this process using a brand new AC family. Same result...
THEN, I tried drawing the profiles rather than using AC families as the profiles (as I had seen in a different link). That was the difference!
Worked like a charm once I oriented those profiles to the axis like you said. Thanks so much!
Now, if only we could eliminate those lines and just have it be a "soft" looking surface... Revit wishlist!
Thu, Sep 25, 2014 at 2:03:25 AM | Adaptive component multi-profile sweep (R13)
revitape
revitape Avatar
4.5 Stars: 9 Votes
Thanks again for the help! Here's the final product... came out pretty good!
Here's the actual product: http://www.falconproducts.com/product/10485/CURV-Chair.html
Profile uploading for model in-place component sweep
Sun, Oct 21, 2012 at 6:28:14 AM
Adaptive component facade profile
Wed, Jan 16, 2013 at 4:34:34 PM
3D Multi-planar Spline Sweep with Adaptive Family
Fri, Mar 21, 2014 at 3:23:47 PM
Multi-profile Sweep
Fri, Jan 22, 2010 at 8:08:14 AM
Adaptive component documentation
Wed, May 11, 2011 at 3:51:41 AM
Page generation time: 2.2286
