9 Users Online (7 Members):
Forums >> Revit Building >> Technical Support >> Cannot select my Grid bubles.
0 Posts No Rating |
Checked opened my active worksets and I own them. Any idea ? I need to erase them but I cannot even highlight them
0 Posts No Rating |
I found the solution, the grid lines are inside an option for some reason that I am not quite sure of but, this is where I can access them. FWIW
You are the one that did this. If they don't belong in the option set, I suggest you move them out before it causes other problems.
Unable to select grid lines after pinning them |
Fri, Dec 13, 2013 at 5:42:49 AM
Can't select Wall and Grid - Not Design Option fault |
Thu, Jun 20, 2013 at 10:30:13 AM
Can't select gridlines |
Fri, Oct 3, 2014 at 10:00:46 AM
Grid Lines & editable dimensions |
Mon, Mar 30, 2009 at 6:11:38 PM
Problems with selecting mullion on curtain grid |
Thu, Jun 12, 2014 at 2:57:54 AM
