Forums >> Revit Building >> Technical Support >> Pull Downs get "tired"
Fri, Jun 25, 2004 at 4:01:43 PM | Pull Downs get "tired"
SteveB
3.5 Stars: 5 Votes
A nagging problem since v5 for me is that pulldown menus [fields in Element Properties] seem to get "tired out" and won't pull down after the program has been open for some period of time. Save, close, reopen and they are back to their normal function. Machine has a meg of memory, plenty of processor speed. This is the only program that does this. Any ideas?
Wed, Oct 27, 2004 at 4:18:43 PM | RE: Pull Downs get "tired"
Deasty
I had a brief problem withthis at home.....the solution for me was to simply move the program window from my "Secondary" Monitor to my primary monitor. don't know if that applies.....but it's what I did.
Design is life displayed in a static medium. Deasty
Thu, Oct 28, 2004 at 8:39:39 AM | RE: Pull Downs get "tired"
SteveB
3.5 Stars: 5 Votes
I just downloaded r7. This problem doesn't seem to occur in r7, thankfully. Unfortunately, the "whats new in r7" pdf is not available from autodesk site, will try again later.
Thu, Oct 28, 2004 at 9:00:23 AM | RE: Pull Downs get "tired"
Mr GG
3.5 Stars: 9 Votes
Have a look here: http://revitcity.com/forums.php?action=viewthread&thread_id=520 And you can find the Preview Guide - a .pdf - with all the news in Revit 7.
Fri, Oct 29, 2004 at 9:00:07 AM | RE: Pull Downs get "tired"
SteveB
3.5 Stars: 5 Votes
too bad, I was wrong - r7 pull downs stop functioning [get "tired"] also.
Fri, Nov 12, 2004 at 10:05:36 AM | RE: Pull Downs get "tired"
SteveB
3.5 Stars: 5 Votes
r7: now the pulldowns stopped functioning completely, even if I shut the program down and re-start. Autocad are you there? hope you fix this!
Fri, Nov 12, 2004 at 2:00:21 PM | RE: Pull Downs get "tired"
Tony
To fix this Go to 'New' on the toolbar click "Project", in the 'Template file' click 'none', in the 'Create new' click 'Project' thats it. I have only had the problem twice in V5.1, this seems to reset revit back to standard. I even reloaded it and it still didn,t work until I tried the above. Hope it works for you . Post edited on 2004-11-12 14:03:34
Fri, Nov 12, 2004 at 4:43:28 PM | RE: Pull Downs get "tired"
SteveB
3.5 Stars: 5 Votes
Tony, this does seem to fix the problem, not sure I know why, but THANKS.
Fri, Nov 12, 2004 at 5:49:06 PM | RE: Pull Downs get "tired"
SteveB
3.5 Stars: 5 Votes
I spoke too soon - the fix lasted 1 hour. Pull downs back to non-function. pain!
Fri, Nov 12, 2004 at 10:26:51 PM | RE: Pull Downs get "tired"
Tony
Do'es it fix it again when you try my fix. The drop downs aren't working but if you type the first letter it will pick it up for example scale or material. I'ts a bit hard to explain. Post edited on 2004-11-12 22:29:58
Sat, Nov 13, 2004 at 6:57:54 AM | RE: Pull Downs get "tired"
#11
SteveB
3.5 Stars: 5 Votes
No, the second time I do your fix it doesn't help. But yes, if you know the names of the pull downs, you can type them in and they will pop in. Like if a door is displayed and you highlight phase demolished and it displays "none", you type "e" and "existing" will be displayed. This doesn't help when it comes to setting the scale of a drawing, numbers don't seem to work.
Tue, Dec 6, 2005 at 8:14:42 PM | RE: Pull Downs get "tired"
#12
Osir
Running Revit on a second screen was the problem for me, too. Thanks for the clue. Now I'm cramped onto a single monitor screen, but at least I can change wall properties.
-IOeser
Creating furr downs above cabinets...
Fri, Jul 13, 2012 at 8:36:37 AM
Download/ Export Walkthrough Video
Thu, May 9, 2024 at 12:46:06 PM
Trying to Import Filled Section Head
Mon, Jun 27, 2016 at 1:18:49 PM
Section Cuts
Thu, Dec 8, 2011 at 8:53:29 AM
Drop Down Issue
Thu, Nov 13, 2008 at 1:38:16 PM
Page generation time: 0.7566
