Forums >> Revit Building >> Technical Support >> Translucent Existing Phase after Rendering
Sun, Sep 21, 2014 at 8:55:01 AM | Translucent Existing Phase after Rendering
PetraS
Hi there,
I use Revit Architecture 2014. I am trying to figure out how to make an Existing Phase to look translucent/transparent after Rendering.I tried to change it in Phasing/Graphic Overrides/Material of Existing phase, but existing phase appears to be just solid grey after rendering. The reason I am trying to do this is to make existing buildings appear like a 'background'. For example, if there is a street of terraced houses and I want to create a new construction between 2 existing terraced houses, I want the new construction to be looking normal, but 2 houses from the both sides would be for example white translucent/transparent or grey translucent/transparent after rendering. So the new construction 'stands out'. It is simply for presentation purposes. Is it even possible to do this in phasing settings?
Thank you.
Sun, Sep 28, 2014 at 7:08:34 AM | Translucent Existing Phase after Rendering
PetraS
And additional question would be: Buildings marked as Existing Phase don't show shadows. Is there a way how to change it?
Thank you
Walls set as existing not showing up in existing phase settings.
Sat, Aug 4, 2012 at 11:21:58 AM
Rendering problems with existing phase
Tue, Sep 19, 2006 at 2:24:36 PM
New Construction phase cuts Existing Phase
Tue, Aug 9, 2011 at 12:21:57 PM
Site and phasing troubles
Mon, Apr 19, 2010 at 5:03:04 PM
Existing Phase Surface Patterns visibility
Tue, Nov 14, 2006 at 6:37:24 PM
Page generation time: 1.8017
