Forums >> Workflow & Implementation >> Hardware >> What should I upgrade to increase Revit performance?
Sun, Sep 21, 2014 at 1:49:56 AM | What should I upgrade to increase Revit performance?
aaron655
Hello
Was wondering if you can share some expertise on what components to upgrade to increase my Revit performance.
I currently have the following:
CPU: Quad Core Q6600
RAM: 4gb
Hard Drive: 500 gb SATA (non solid state)
OS: 32 bit windows 7
Any tips would be much appreciated!
Sun, Sep 21, 2014 at 1:54:03 AM | What should I upgrade to increase Revit performance?
aaron655
I should also note my graphics card is: GeForce GTX 750
Sun, Sep 21, 2014 at 9:53:59 AM | What should I upgrade to increase Revit performance?
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Take a look here: http://www.revitforum.org/hardware-infrastructure/75-revit-hardware-general.html
Tue, Dec 8, 2015 at 9:17:57 AM | What should I upgrade to increase Revit performance?
lolcocks
Your system is too low on hardware for running Revit.
Expecially large projects.
I would recommend upgrading.
Fri, Oct 7, 2016 at 11:36:43 AM | What should I upgrade to increase Revit performance?
rbcameron2
rbcameron2 Avatar
4 Stars: 25 Votes
SSD and as new of i7 or Xeon processor you can afford.  At least 8gb of RAM but the new minimum has already become 16gb
RB Cameron
3D Medical Equipment
Download Revit Healthcare Models Now
Download Other Revit + 3dsMax Models Here
Tue, Jan 24, 2017 at 4:54:04 PM | What should I upgrade to increase Revit performance?
JustinDaffara
Can we know which Revit Product you have.
You can check the system requirement in below given web link.
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles/System-requirements-for-Autodesk-Revit-products.html
Thank you,
Justin Daffara
http://www.apps4rent.com/office-365-resellers.html
Edited on: Tue, Jan 31, 2017 at 10:15:39 PM
Slow Model? – How to Increase Revit Performance
Thu, May 23, 2013 at 2:22:22 PM
File size and performance with multiple instances of 3d families
Wed, May 26, 2010 at 4:10:42 PM
UPGRADE QUESTION
Mon, Jun 12, 2006 at 9:03:39 AM
Worksets
Fri, Apr 14, 2006 at 3:07:09 PM
UPGRADE problem!!!
Wed, Jun 28, 2006 at 6:35:24 AM
Page generation time: 2.2695
