Forums >> Revit Building >> Technical Support >> Can't Get Modify Schedules/Quantities tab to turn off - Revit 2014
Fri, Sep 19, 2014 at 11:39:58 PM | Can't Get Modify Schedules/Quantities tab to turn off - Revit 2014
JCully
No matter what I am working on in my project, the modify schedules/quantities tab is always lit up, like I'm in the middle of modifying a schedule.  The problem is, I'm not.  Example, if I try to draw a wall, I go to the Architecture tab, select wall, and it automatically flips back to modify schedules tab. The modify walls is also lit up at this point, but I have to select it at the top to get off the modify schedules tab.  I don't know how this happened, but it's there even if I close the program and reopen with a new project.  Does anyone know how to fix this problem?  I feel like it should be easy to fix, but I can't seem to figure it out.
Thank you!
Jennifer
Mon, Sep 22, 2014 at 7:15:57 AM | Can't Get Modify Schedules/Quantities tab to turn off - Revit 2014
What updates do you have installed?
Tue, Nov 25, 2014 at 9:51:09 AM | Can't Get Modify Schedules/Quantities tab to turn off - Revit 2014
JAATO
Has this issue been resolved? I'm having the same problem here...
Tue, Nov 25, 2014 at 10:38:53 AM | Can't Get Modify Schedules/Quantities tab to turn off - Revit 2014
JAATO
Not resolved yet.
Edited on: Tue, Nov 25, 2014 at 11:50:47 AM
Tue, Nov 25, 2014 at 12:55:48 PM | Can't Get Modify Schedules/Quantities tab to turn off - Revit 2014
Again ... what updates do you have installed.   Give us the latest number - not just a yes.
Thu, Mar 30, 2017 at 1:15:02 PM | Can't Get Modify Schedules/Quantities tab to turn off - Revit 2014
jenpark0
Go to Opotions > User Interface > Toggle off Display the contexual tab on selection at the bottom
How to include the Level parameter in Wall Schedule & quantities
Mon, Sep 25, 2006 at 7:34:35 AM
RAC 2012 Modify Tab on Ribbon
Thu, Jul 5, 2012 at 10:27:41 AM
Revit 2014 schedules... where did the Show button go?
Mon, Dec 16, 2013 at 2:18:43 PM
Drafting View/Schedules for quantities
Thu, Mar 29, 2012 at 9:17:18 AM
Tue, Dec 20, 2005 at 10:05:21 AM
Page generation time: 4.8892
