18 Users Online (16 Members):
Forums >> Revit Structure >> Technical Support >> Material Description to be scheduled
1 Posts No Rating |
Please, tell me what is the better way to list Material Description of elements.
I've been triying to make a Multicategory Schedule, but I´m not sure how to creeate a shared parameter for material description.
I need to show the following fields:
Material Take off Code(is a shared parameter)
Category
Material Description (I need to create a shared parameter too)
Type
Template (yes or no parameter)
Thank you
In order to schedule anything, the element must be present in the model.
A material take off might be more useful because most of these parameters already exist> But agin - the material must be used in the model.
You can add shared parameters to materials from within the project environment. Project Parameters.
1 Posts No Rating |
There are elements present in the model.
I have a seven story building with structural columns and beams with Materials and a Material Description, so I want to know how to create the shared parameter, I mean wich values, groups, categories I must select to list the material description becouse I will use these values to indicate the specifications of the construction process and differentiate the elements.
Thank you
Scheduling Door Material with yes/no Paramters |
Fri, Dec 16, 2011 at 10:24:05 AM
Revit 2013 Material User Interface |
Thu, May 2, 2013 at 4:50:53 PM
Wall Material Takeoff vs. Wall Quantity Takeoff for material description |
Mon, Mar 15, 2010 at 1:57:00 PM
material tag schedule problem |
Sat, Mar 25, 2017 at 7:50:36 AM
Material Tag ??Override/Hack?? |
Thu, Aug 30, 2012 at 2:35:23 PM
