18 Users Online (16 Members):
Forums >> Revit Building >> Technical Support >> PNG- TRANSPARENCY- COLOR SCHEME
2 Posts No Rating |
I am attempting to have tenant logos on our floor plans. I have saved all of the logos as PNGs with a transparent background and when I insert them on the plan, they work fine. The color scheme applied to the floor plan shows through the background as desired on the screen.
The problem comes when I go to print- to printer or PDF- and the background of the images is no longer transparent but white. Has anyone else had this issue? Is it related to the image or the color scheme?
I have tried saving the PNG in multiple ways, 32bit, 16bit, etc and there is no change. This happens in both 2014 and 2015, all updates installed. The color scheme uses solid fills for all values, PNGs all set to foreground.
Using Revit2014, dragging the rest of the company with me from AutoCAD2008. When will the whining stop? |
2 Posts No Rating |
SOLUTION: There was a view template applied and in that view template only the color scheme was set to Foreground instead of Background. Changing it to Background made the PNG backgrounds transparent again.
Didn't even know that option existed for color schemes!
Good post - thanks for sharing the solution
I still get this problem with no template applied in 2017 and 2018
color scheme disappear |
Fri, Sep 24, 2010 at 7:49:22 PM
new color scheme entry error |
Thu, Sep 18, 2014 at 1:42:54 PM
12
Color Scheme Legend Issues |
Mon, Dec 1, 2014 at 6:26:38 AM
Color Scheme Problems |
Tue, Jun 26, 2007 at 11:53:16 PM
ZONE COLOR SCHEME |
Thu, Sep 30, 2010 at 6:18:26 AM
