Forums >> General Discussion >> Revit Project Management >> Revit to DWG in one single flie.
Wed, Sep 17, 2014 at 11:08:51 AM | Revit to DWG in one single flie.
titorizo
4 Stars: 1 Votes
I have wasted multiple hours exporting dwg's from revit and then combinding them into a single dwg file for consultants.
Is there a way to export all of my sheets from revit and have the drawing located all on one dwg file?
Wed, Sep 17, 2014 at 11:24:33 AM | Revit to DWG in one single flie.
Why are you combining them?  Typically CAD is all seperate files.  That's one of the reason's Revit is so much better than CAD.
Wed, Sep 17, 2014 at 12:43:57 PM | Revit to DWG in one single flie.
titorizo
4 Stars: 1 Votes
Unfortunately our consultants perfer to only have 1 dwg to work with, with the entire project in it vs. having to open multiple files or a folder of xrefs.
Wed, Sep 17, 2014 at 12:52:22 PM | Revit to DWG in one single flie.
You said files - not x-refs.  Which ones are you talking about?
You have an option during exporting to "Export views on sheets and links as external references".  Uncheck that box and you won't have x-refs.
Fri, Sep 19, 2014 at 11:26:23 PM | Revit to DWG in one single flie.
Jamie351
Jamie351 Avatar
4 Stars: 7 Votes
I have to export all views then copy paste them all into the one cad file.
Floor plans, Elevations, Sections, Site plans etc all in one file for consultants. bit annoying....
Revit 2018........
Mon, Sep 22, 2014 at 4:01:47 PM | Revit to DWG in one single flie.
zsmith3
Make a giant sheet family (really long, but wide enough to fit typical plans). It can be ridiculously long. Place all the views on this sheet, export it to DWG making sure to uncheck export views as xrefs.
2D DWG Convert to 2D Revit
Mon, Nov 23, 2015 at 1:57:38 PM
Revit 2012 Export To DWG. Titleblock exported as Block.
Wed, Jun 12, 2013 at 6:16:23 PM
Exporting views with DWG bocks to dwg.
Sun, May 21, 2006 at 8:36:59 PM
Revit to DWG
Fri, Jan 14, 2011 at 11:56:25 AM
Solution 2D DWG to REVIT Pls
Sun, Jun 18, 2006 at 6:04:13 AM
Page generation time: 1.3245
