Forums >> Revit Building >> Technical Support >> Adding a reference elevation to an existing elevation marker?
Tue, Sep 16, 2014 at 10:58:57 AM | Adding a reference elevation to an existing elevation marker?
ArchiN00B
ArchiN00B Avatar
4.5 Stars: 4 Votes
I have an existing elevation marker that I set up as a reference to a drafting detail, facing West.
I want to add an elevation marker to the same bubble, facing North, that references a different drafting detail. I can't find any way to tell an elevation marker to reference an existing detail except the option in the ribbon when you're placing the first elevation. How do you reference a detail with a second/third/fouth marker? When I click the box to add the elevation facing North, it creates a new blank elevation, and I can't reference an existing one.
Any ideas? Thank you.
Wed, Sep 17, 2014 at 7:57:46 AM | Adding a reference elevation to an existing elevation marker?
Sorry - reference other view is not possible for multiple references.
If it is the same sheet, just place your reference other view under your new callout.
Split a an elevation marker up for mulitple sheets
Tue, Oct 4, 2016 at 2:29:34 PM
Double-side elevation marker where one is the reference of another
Thu, Feb 26, 2015 at 10:02:57 AM
ELEVATION MARKER
Thu, Sep 10, 2009 at 2:55:39 PM
If your elevation markers on plan disappear.
Fri, Mar 4, 2016 at 3:40:45 PM
adding an elevation swing projection to a cabinet elevation
Thu, Jun 14, 2007 at 2:48:01 PM
Page generation time: 5.6512
