Forums >> Revit Building >> Technical Support >> I can't see wall with section lines eventhough cut plan passes through the wall!
Mon, Sep 15, 2014 at 7:23:21 PM | I can't see wall with section lines eventhough cut plan passes through the wall!
mehdiho
I created a wall that "Top Constraint" is "Unconnected" and "Unconnected Height" was set to 1.60 meters.
But surprisingly on the plan view it shows with projection lines! I checked the "View Range" and the "Cut Plan" is set to 1.0 meter! So it should defiantly shows it with cut lines.
 I found out if the wall height is 1.70 or higher, I can see the wall has been cut. so where this magic number comes from? it has nothing to do with Cut Plan and View Range ! why?
Mon, Sep 15, 2014 at 9:42:29 PM | I can't see wall with section lines eventhough cut plan passes through the wall!
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
This is a normal behavior. Unconnected walls shorter than 6’ (I think) are displayed with projection lines. Instead of unconnected wall, make it to the level above and apply negative top offset so it’s 1.6m.
Hatching / cut planes
Mon, Dec 5, 2005 at 5:15:19 PM
Wall Section won't show in both plan and building section
Wed, Jan 29, 2014 at 6:52:25 AM
Wall Cut Pattern Plan View vs. Section
Fri, Jan 6, 2012 at 11:19:21 AM
Wall cut patterns
Fri, Jun 16, 2006 at 1:29:23 PM
Sink Family - Symbol Lines won't flex with Wall Change in Section View
Mon, Mar 9, 2009 at 5:26:15 PM
Page generation time: 1.3041
