Forums >> Revit Building >> Technical Support >> basic question about walls...
Sat, Sep 13, 2014 at 11:10:56 AM | basic question about walls...
mehdiho
every time I draw a wall I undrestand that I can specify the wall goes from (for instanceSmile level 1 to level 2.
then, I have to manually sellect each walls to "Ataach Top/Base" to the upper floor. (that's a hassle !)
Consider at the beggining I dont know how thick is my floors , so I cannot use "Top Offset".
is there any way that all walls attch automatically to the upper floor/s?
Thanks
Sat, Sep 13, 2014 at 12:12:15 PM | basic question about walls...
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
When you have your level 1 walls in place and when you model level 2 floor, you will get this message (see pic). If you modeled your level 2 floor before walls, you can enter floor edit sketch mode and without making any changes exit from there clicking on the green check mark – you’ll get the same message.
Be careful though, you might have some walls that you don’t want to connect, use it with caution.
Sat, Sep 13, 2014 at 12:17:40 PM | basic question about walls...
mehdiho
Thank you so much
REVIT Architecture 2009 Basic Architectural Convention question [ 1 2 ]
Tue, Oct 21, 2008 at 8:19:58 AM
15
Unique Walls
Tue, Jan 8, 2013 at 7:11:19 AM
Exterior Floor Question
Fri, Jun 5, 2009 at 2:17:52 PM
Basic Material Question
Thu, Mar 8, 2012 at 1:01:40 AM
Create a "Foundation Wall system family?"
Tue, Aug 3, 2010 at 9:50:54 PM
Page generation time: 1.2218
