Forums >> Revit Building >> Technical Support >> Background fade during Boundary Edit
Fri, Sep 12, 2014 at 4:05:24 PM | Background fade during Boundary Edit
DukeW
Hi, all.  Revit 2014 user.
Normally, when you create or edit a boundary sketch, the background linework fades and the boundary you are working on  stays dark.
We have 1 specific model where that doesn't happen.  If you try to edit a boundary, all the background linework stays black, making it very difficult to isolate the object you're editing.  I can have windows from 2 projects open, and in 1 it will behave normally (with the faded background) and in the other, it will not.
I assume this is a setting issue in that 1 model, but I am having no luck finding it.  Can someone please point me in the right direction?
Thanks.
Edited on: Fri, Sep 12, 2014 at 4:05:54 PM
Mon, Nov 3, 2014 at 12:01:27 PM | Background fade during Boundary Edit
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
The background darkness during sketching defers to the 'Halftone' setting.
Manage > Additional Settings > Halftone / Underlay.
Mon, Nov 3, 2014 at 12:08:31 PM | Background fade during Boundary Edit
DukeW
Excellent, thank you for the reply.  I'll give that a look.
Revit won't (Grey/Halftone/Fade) during any Sketch/Edit/Modify mode
Tue, Feb 27, 2018 at 11:18:53 AM
Beam System is not resetting after I edit the boundary.
Mon, Jun 15, 2015 at 2:35:42 PM
Ceiling edit boundary problems
Wed, Apr 18, 2012 at 12:59:37 PM
text edit box background
Thu, Feb 26, 2009 at 8:59:12 AM
stair boundary
Mon, May 16, 2016 at 4:51:31 AM
Page generation time: 2.1247
