Forums >> Revit Building >> Technical Support >> 3D CAD import Part and masking region
Thu, Sep 11, 2014 at 5:53:26 PM | 3D CAD import Part and masking region
Warchitect
4 Stars: 5 Votes
Im trying to create a wolf range 3D CAD block for my revit model. The 3D CAD part is completely wire framed in all views but the 3D view. So in plan you can see through it to the floor pattern underneath. I want to add then a masking region to the family so it wiped out the floor under (in plan), but still shows the range itself. But the masking region covers everything.
any help would be cool. I cant "move to back" the masking region so my plan view lines show through. :-(
Fri, Sep 12, 2014 at 8:28:31 AM | 3D CAD import Part and masking region
Place a very thin extrusion under the stove and set it to show only in plan.
Fri, Sep 12, 2014 at 12:37:57 PM | 3D CAD import Part and masking region
Warchitect
4 Stars: 5 Votes
haha! thats exactly what I ended up doing! Great minds!
Was curious though, there is no "send to back" commands in the families editor. Seems like the perfect tool, but there must be some reason that it can't
Thanks
Fri, Sep 12, 2014 at 1:35:17 PM | 3D CAD import Part and masking region
Your problem is how the CAD was done.  If it had a solid in it high enough, then you would not have to do this.
Masking regions hide everything except 2D elements including text and dimensions.
Sun, Sep 14, 2014 at 2:36:26 PM | 3D CAD import Part and masking region
Warchitect
4 Stars: 5 Votes
Cool.
Note though, you CAN do the masking region in a "detail item" family. If you DL a CAD file from a supplier (say a range dwg) and import that cad into a detail item family, then you can make a masking region and send it under the CAD lines, getting a nice family to insert that masks floor tiles etc..., but its only a flat 2D element. Sort of works for detail plans, where you have a lot of equipment and such.
How to I have a fill region or masking region and have my CAD import over it?
Tue, Oct 20, 2015 at 1:09:06 PM
Masking Region Fill Region Problem
Mon, Mar 10, 2008 at 11:06:24 AM
Masking region at section callout head.
Tue, Jul 30, 2013 at 1:43:26 PM
Invisible Masking Region outline
Tue, Jul 12, 2016 at 12:11:33 PM
Masking region do not mask as expected
Mon, Apr 29, 2013 at 8:34:59 PM
Page generation time: 0.3415
