Forums >> Revit Structure >> Technical Support >> How to show beam column connection in plan properly
Thu, Sep 11, 2014 at 10:04:53 AM | How to show beam column connection in plan properly
McMarcus
I have a condition where a beam rests on top of the column. If I draw the model correctly, the beam overlaps the column in plan and the moment symbol covers up the column. Is there a way to show the beam offset in plan without detaching from the column but correct in the model and section? The snapshot named Reality and Section is reality and the snapshot named Symbolic is how I'd like to show it in plan.
Thank you!
Fri, Nov 7, 2014 at 12:53:30 PM | How to show beam column connection in plan properly
aandr001
4.5 Stars: 6 Votes
I think what you're looking for is found in "Symbolic Representation Settings".  To get there, go to your structure tab and click on the little diagonal arrow to the right of the structure tab.  Here you will find settings for how far the symbolic cutback distance is.  This distance is also affected by whether you have your plan view set to coarse, medium or fine.
column-beam connection
Tue, Jan 12, 2010 at 5:46:46 AM
Need Help on Sloped Beam-Column Connection
Fri, Apr 29, 2016 at 1:50:43 PM
beams not snapping to beam/column
Fri, Feb 19, 2010 at 4:30:22 PM
Column to diagonal beam/brace connection problem
Fri, Apr 23, 2010 at 4:40:24 AM
Steel Beam to Beam Connection
Fri, Jun 18, 2010 at 1:54:36 PM
Page generation time: 0.7474
