Forums >> Revit Structure >> Technical Support >> Analytical Lines creates blank space in schedule in revit str 2014
Thu, Sep 11, 2014 at 7:55:10 AM | Analytical Lines creates blank space in schedule in revit str 2014
albertiglesia
albertiglesia Avatar
Hi,
Good Morning
Is there anyone here already encountered the problem of empty space / row in your Structural Beam / Slab / RC Wall / Column schedules when the analytical lines is enabled? How do you remove the black space in the schedule while maintaining the analytical line in the model?
I am using Revit Structures 2014
Thanks in Advance
Smile
"Pleasure in the job puts perfection in the work"
 - Aristotle
Thu, Sep 11, 2014 at 8:10:30 AM | Analytical Lines creates blank space in schedule in revit str 2014
albertiglesia
Additional detail:
The schedule are in the sheet model
Sheet Model is a revit file that consist of 2 or more x-ref revit files that houses all the sheet drawings that you need to submit to the client (GA Plans, Sections, Details, Schedule, etc)
x-ref revit file is where you model the project structure
Edited on: Thu, Sep 11, 2014 at 8:16:04 AM
 - Aristotle
Schedules & Blank Space
Tue, Nov 4, 2008 at 11:09:20 AM
Adjusting the analytical line in a revit family
Fri, Mar 5, 2010 at 9:16:30 AM
CAD files importing with huge blank space [ 1 2 ]
Fri, Sep 3, 2010 at 11:43:39 PM
16
Revit Schedule Mask? Dummy text to make space between lines....
Tue, Jul 30, 2013 at 9:58:23 AM
Resetting/fixing the analytical model (Revit Structure 2014)
Wed, Jan 15, 2014 at 8:56:48 AM
Page generation time: 2.5139
