Forums >> Revit Building >> Tips & Tricks >> Best Trim building workflow
Mon, Sep 8, 2014 at 12:33:17 PM | Best Trim building workflow
Balitog
what would be the best workflow to create the trim around the doors and windows on this wall? Extrusions, sweeps, else...
Please advise
Thanks
Mon, Sep 8, 2014 at 12:53:48 PM | Best Trim building workflow
No trim type given.  ...
There are so many possibilities but since you asked a simple question - for a simple picture frame trim (that has a profile) with mitered corners
  • a sweep in the door family
  • a face based family with a seep
  • a sweep in the project using the wall face as the work plane
If you want something else then you need to reframe your question.
https://www.google.com/search?q=door+trim+ideas&client=firefox-a&hs=qeP&rls=org.mozilla:en-US:official&channel=sb&tbm=isch&tbo=u&source=univ&sa=X&ei=2e0NVJ3QApCcyASN1ICwCw&ved=0CD4QsAQ&biw=1275&bih=932
Edited on: Mon, Sep 8, 2014 at 12:57:28 PM
Wed, Sep 10, 2014 at 2:48:41 PM | Best Trim building workflow
Balitog
Let me reframe the question. What is the best way to create trim around ganged windows or ganged doors? If I use one type of windows close to each other and the family has its own surrounding sweep, the "in between" trim will have lines showing where the construction will be one piece. What is the best way to create this in Revit.
See image for what I am looking for. As you can see there are twin and quadruple units together. This is what I am looking for. Note that the apron below the windows is a different profile
Thank you
Wed, Sep 10, 2014 at 3:01:06 PM | Best Trim building workflow
That is a much better question.
If trim is to be included in the family, then ganged windows need to be ganged in the family.  That is typically the preferred process.  Then to get trim as you show, the trim should be separate extrusions on the wall face - no sweeps required.  If the trim pieces are tot rectangular, then they need to be separate sweeps but they could also be extrusions.
The garage door trim looks like it should be one sweep.
Edited on: Wed, Sep 10, 2014 at 3:02:22 PM
Wed, Sep 10, 2014 at 3:12:38 PM | Best Trim building workflow
Balitog
Thanks, I think I will work with wall sweeps.
Best
CF
Wed, Sep 10, 2014 at 3:38:06 PM | Best Trim building workflow
Wall sweeps is the worst and hardest way to go.
Good Luck
Thu, Sep 11, 2014 at 10:29:08 AM | Best Trim building workflow
Balitog
I was thinking that I could actually align the profiles to the wall openings rather than creating a family with multiple windows. Alternatively I looked at the family that comes with revit called the combination Rtp with Trim but I don't understand how the vertical middle mullion is set/constrained and how to modify its width to fit my needs. Also, are the windows used family items themselves?
Thu, Sep 11, 2014 at 10:39:34 AM | Best Trim building workflow
"...I was thinking that I could actually align the profiles to the wall openings..."  << You mean with in-place sweeps - not wall sweeps?  Yes, you can do that in the project or in the family.
For a multiple family window, you should probably stay away from parametrics if you are not yet proficient at building families.  Just edit a single type, increasing the wall cut to accomodate two and copying the window componets all togetehr to the scond location.  Then add the trim and center mullion.
I've got dentel (sp?) trim on an existing building that I need to match.
Fri, Jan 7, 2005 at 11:07:45 AM
trimming trim corner.
Wed, Feb 1, 2012 at 12:09:41 PM
workflow for architectural building section showing roof trusses.
Wed, Jan 10, 2018 at 10:12:23 AM
door trim stops short of floor
Wed, Jul 24, 2013 at 3:24:32 PM
Trim Roof Facia
Sun, Jul 3, 2016 at 12:18:25 PM
Page generation time: 0.2627
