14 Users Online (12 Members):
Forums >> Community >> Newbies >> Elevations hidden
Hi Everyone!
I am new to revitcity, i hope i will find it helpful...
I have drawn a multistory building in revit 2014 everything works fine with model but when i go to elevation i cant find them, although there is all set levels but not elevations not appears, can anybody help how i can see my elevations?
Thanks
Ali
In the view properties, make sure the phasing of the elevations and the floor plans matches, also try unchecking crop view and zoom all.
Thanks Pijipiwo
I have tried to check view and all settings in for elevations, but didnt worked, only i can see west elevation nothing else...if you could help me...
thanks
In the elevation view in question, set Far Clipping to No Clip in the view properties under Extents. If still no good, can you upload your file so we can troubleshoot or at least some screen shots of the elevation and plan view properties?
The elevation view has to point at the elements, it has to be deep enough to include them and it has to be high or low enough to show the model. Check out all of those in appropriate views.
MASSES SHOW UP AS HOLLOW OBJECTS IN ELEVATIONS IN HIDDEN LINE MODE |
Fri, Aug 11, 2006 at 1:18:15 PM
Hidden Lines disappeared from all my Elevations |
Fri, Mar 1, 2013 at 12:37:04 PM
Hidden lines in elevations |
Mon, Sep 10, 2007 at 9:43:06 AM
Elevation/Creating Hidden lines |
Fri, Mar 12, 2010 at 12:43:17 PM
Please Help: Seeing wireframe pieces in a hidden line elevation [ 1 2 ] |
Fri, Jun 17, 2016 at 11:04:14 AM
20
