Forums >> Revit Building >> Technical Support >> Adding risers to bottom of stair?
Fri, Sep 5, 2014 at 2:49:28 PM | Adding risers to bottom of stair?
scochrancpslo
I'm working in Revit 2014 & I have an already modeled, somewhat complex stair that I now need to add some risers too because of a change in floor heights.  While I have plenty of room in plan to extend the bottom end of the stair I have no room in plan to extend the upper end.  However, when I try to edit the stairs I appear to only be able to add risers to the top of the stair which would then require relocating all of the landings & runs below that (the entire stair...) in order to get them back in their correct plan locations.  Am I missing something really obvious?  Surely I don't actually need to re-model the entire stair in order to change the bottom start location?
Fri, Sep 5, 2014 at 3:29:36 PM | Adding risers to bottom of stair?
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Component stair or by sketch? Can you provide some pics?
Fri, Sep 5, 2014 at 3:55:03 PM | Adding risers to bottom of stair?
scochrancpslo
It's a component stair, see attached image.
Fri, Sep 5, 2014 at 4:05:40 PM | Adding risers to bottom of stair?
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Grab the blue dot of the lower run and stretch.
Edited on: Fri, Sep 5, 2014 at 4:07:48 PM
Edited on: Fri, Sep 5, 2014 at 4:08:23 PM
Fri, Sep 5, 2014 at 4:21:25 PM | Adding risers to bottom of stair?
scochrancpslo
Fri, Sep 5, 2014 at 5:04:09 PM | Adding risers to bottom of stair?
scochrancpslo
Okay, so that gave me the attached error message, which is what I was getting before regardless of whether or not I'd already adjusted the bottom stair elevation in the properties.  But, in checking it again I noticed the blue triangle next to the blue dot can be selected independently & moving that actually does add risers to the bottom, though it steals them from the top of the stair.  But at least I can add risers back in at the top of the stair so I'll take it.  Not sure what would happen if I had to "steal" more risers than I had in my top run but I'll worry about that another day.
Fri, Sep 5, 2014 at 6:32:51 PM | Adding risers to bottom of stair?
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
This error message usually pops up when you try to extend the run (blue dot) below stair base, but you said no base offset from level was applied, …well then, must have been something else (?).
You can also adjust the run and shape handle (blue dot and triangle) in the elevation view. Kinda nice when you can see the change in the stair shape in real time.
stair constraint issues - new user - revit 2008
Wed, Mar 26, 2008 at 1:50:54 PM
2009-Stair Error-Mystery
Thu, Jun 25, 2009 at 7:02:13 AM
Stair Risers and Calculations?!! Very Urgent!
Tue, Nov 10, 2009 at 12:41:00 PM
Custome Stair Risers - don't match stair presets
Tue, Nov 24, 2009 at 3:01:41 PM
Stair Winder issue
Thu, Feb 9, 2012 at 5:31:14 PM
11
Page generation time: 0.4253
