22 Users Online (20 Members):
Forums >> General Discussion >> Revit Project Management >> Join Objects in Array
31 Posts No Rating |
Is there a way to join the objects being arrayed? Each object in my array tuches at the end and creates a line. I would like this line to go away and look as if it is one contiunies pice. Join works on a manual bases but does not array with the objects.
Thanks,
smh
We need more information.
If a wall that is joined to a perpindicular wall is arrayed along that wall, all the walls will be joined. So obviously you need to be more descriprive.
You might try not grouping the objects.
Sorry about that. I am trying to make a comstome family. The arrayed pice (object 1) was built in a genaric model family and then imported into this family. Object 1 is a single exstution. When it is arrayed the end edge of one is flush against the start edge of the next. Because of this the edge lines show up. Join works but I cannot get it to array. I am trying to make it look as if there are no seams in the array.
Hope this helps,
smh
Can I have objects in a parametric array change height? |
Fri, Sep 3, 2010 at 3:06:21 AM
Changing Dimension object in Array |
Thu, Jul 27, 2017 at 6:05:05 AM
Array Objects |
Sun, Oct 17, 2010 at 7:06:08 AM
array of nested objects |
Tue, Oct 14, 2014 at 2:27:27 PM
Revit Structure 2012 Multiple Array Visibility |
Tue, Jan 29, 2013 at 1:22:15 PM
