Forums >> Revit Building >> Technical Support >> Eleveation Markers not showing in foor plan
Fri, Aug 29, 2014 at 11:17:29 AM | Eleveation Markers not showing in foor plan
vanderloo
I have vg settings set to show elevations and they do show up in my level 2 view but,
for the life of me, I can't get them to show up in Level 1. It's not a crop region issue.
When I turn on show crop region and expand it I still can't see the
elevation  markers.
(Revit 2015)
Fri, Aug 29, 2014 at 11:32:26 AM | Eleveation Markers not showing in foor plan
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Are they hidden?  They can be turned of in VG but still hidden, turn on the light bulb and see look
In your elevation is your crop region set below the first floor?
Edited on: Fri, Aug 29, 2014 at 11:33:43 AM
Fri, Aug 29, 2014 at 12:21:05 PM | Eleveation Markers not showing in foor plan
vanderloo
No, not hidden. Elevation crop is ok.
As a result of this I have nothing showing up in my North and West elevations.
Fri, Aug 29, 2014 at 12:53:03 PM | Eleveation Markers not showing in foor plan
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Create a new elevation in your first floor plan, do they show up or do you get an error?  If they show up with no error then your elevation markers are off in space somewhere, uncrop your floor plan and zoom extents with the lightbulb on.
Fri, Aug 29, 2014 at 1:12:02 PM | Eleveation Markers not showing in foor plan
Look at the elevation.  Does it show the lower level?  The elevation view has to cross the plan cut level in order to show up in the plan view.
Also, are both views the same scale?  View callouts can be set to hide in views coarser than ....scale....
Fri, Aug 29, 2014 at 2:17:46 PM | Eleveation Markers not showing in foor plan
vanderloo
OK. Figured it out. When doing a remodel, and the view is set to existing, the elevation markers don't show up because they are
set to show in "New Construction". So, when I change the view phase to new construction, they appear. So I moved them to where my
building is and all is good now.
Edited on: Fri, Aug 29, 2014 at 2:18:22 PM
Elevation markers
Thu, Oct 19, 2006 at 11:46:46 AM
elevation markers disapeared
Wed, Jan 13, 2010 at 3:59:29 AM
Sections lines not visible in certain plan views.
Wed, Dec 14, 2005 at 11:30:15 PM
Elevation Markers, Level Heads, Section Markers, all at Varing Scales
Mon, Feb 20, 2012 at 11:33:58 AM
Detail markers?
Sat, Apr 5, 2008 at 2:32:19 PM
Page generation time: 0.3999
