Forums >> Revit Building >> Technical Support >> PLAN REGION VIEW DEPTH CHANGE OVERALL FLOOR PLAN
Fri, Aug 29, 2014 at 11:10:10 AM | PLAN REGION VIEW DEPTH CHANGE OVERALL FLOOR PLAN
LOSpistos
Hi guys,
so im having an overall floor plan (Level 01) and in the middle of it there is courtyard set -1.0m below so with default view depth settings i cant see it. There is just blank space. So i took the plan region tool to create a boundary with different view depth to be able to see the podium below.
BUT
everytime i change plan region view depth settings it has somehow affect on the overall floor plan settings.
I just dont understand how it can change view settings of the floor plan..
Any help will be relaly appreciate im in my ends!
Thanks
Luba
Fri, Aug 29, 2014 at 11:14:12 AM | PLAN REGION VIEW DEPTH CHANGE OVERALL FLOOR PLAN
Images would help:
  1. floor plan showing plan region
  2. View properties showing view range settings
  3. View range settings for plan region
Fri, Aug 29, 2014 at 11:26:47 AM | PLAN REGION VIEW DEPTH CHANGE OVERALL FLOOR PLAN
LOSpistos
Fri, Aug 29, 2014 at 1:08:08 PM | PLAN REGION VIEW DEPTH CHANGE OVERALL FLOOR PLAN
You have not shown us how it does what you say.  The view settings you show are for the plan region only.
Fri, Aug 29, 2014 at 1:12:16 PM | PLAN REGION VIEW DEPTH CHANGE OVERALL FLOOR PLAN
LOSpistos
Yep only for plan region and u can see that the second image shows the topography on the sides whoich shoudlnt be there as i change the view depth in the left courtyard area..
Fri, Aug 29, 2014 at 1:27:29 PM | PLAN REGION VIEW DEPTH CHANGE OVERALL FLOOR PLAN
Sorry but the only change I see is in the plan region area and it is supposed to change!
See side by side below
PLAN REGION PROBLEM
Wed, Sep 10, 2014 at 11:15:22 AM
11
Cant see site features in First Floor Plan
Thu, Jan 31, 2008 at 7:10:59 AM
View Range/Plan Region Visibility Controls in RCP
Wed, Feb 1, 2012 at 11:20:32 AM
plan region/view range window
Mon, Feb 9, 2009 at 4:39:34 PM
Plan Region
Fri, Jul 21, 2006 at 4:23:10 PM
Page generation time: 1.6427
