Forums >> Revit Building >> Technical Support >> Inserting Mass into project troubles
Wed, Aug 27, 2014 at 4:41:44 PM | Inserting Mass into project troubles
Dan7777
Hello, I have created a mass and wish to load it into my project but everytime I try I get the same error message which reads "you cannot change the loaded family Family3 to the mass category because it has instances, you must remove any instances from the other category before you can move the family to this category" Please someone guide me in the right direction here im not sure what Revit is asking.. The family is attached.
Thu, Aug 28, 2014 at 7:40:39 AM | Inserting Mass into project troubles
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I did not have a problem loading it.  Does this work for you if you create a new project?
Conceptual Mass Project Space Visibility
Fri, Jul 15, 2011 at 1:46:11 PM
Unable to load conceptual mass into project
Fri, Sep 11, 2015 at 1:40:26 PM
Using mass in more than one project
Tue, Nov 28, 2006 at 2:19:12 PM
Inserting a 2D Component into a new project sheet [ 1 2 ]
Fri, Jun 22, 2012 at 8:39:40 AM
20
Sharing Coordinates Conceptual Mass Environment and Project Environment
Sat, Nov 16, 2013 at 10:14:00 AM
Page generation time: 2.8497
