Forums >> Revit Building >> Technical Support >> room is not in a properly enclosed region
Wed, Aug 27, 2014 at 3:20:36 PM | room is not in a properly enclosed region
jamiekgoettl
I am getting the message "room is not in a properly enclosed region". I assuming it is because I dropped my walls from being conected to the above floors to below the metal open-web joists. I did add cielings thinking it would be the fix since they are room bounding but it still reads the same. Please help! Thank you
Wed, Aug 27, 2014 at 3:48:38 PM | room is not in a properly enclosed region
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
This post may help you with your problem
http://www.hokbimsolutions.com/2013/12/read-your-warning-messages.html
Wed, Aug 27, 2014 at 4:08:02 PM | room is not in a properly enclosed region
jamiekgoettl
Thank you! That did it!
Room tag callout says room "not enclosed"
Mon, Oct 25, 2010 at 7:12:40 AM
2009 ROOM BOUNDING - non enclosed errors
Thu, Jul 24, 2008 at 9:28:34 PM
Rooms Not Enclosed
Wed, May 27, 2009 at 10:45:36 AM
12
room tags
Wed, Mar 15, 2006 at 6:25:41 PM
Room tag not showing in only one room. [ 1 2 ]
Sat, Sep 27, 2025 at 3:40:00 AM
15
Page generation time: 1.2206
